What a joke? "We can not port a new number to an active Fizz sim card".
Porting can only be done to a inactive SIM card. If you want to change your current number on your account, you will need a second SIM card to activate. During the activation you can port your Rogers number on to the new SIM card. The advantage of a Fizz SIM card is that you can reuse it on another activation.
Fairly sure that's the way it is with all companies. Once the card's activated to an account, you can't re-activate it to another one...
I think you can only port to inactive sims. Don't believe there's anything you can do now, unless you get a new sim
To my knowledge porting can be only done on an inactive sim. Try contacting their help on facebook messenger, or live chat on their website. :)
You can probably have them deactivate the sim, and then you can port the number to a new plan on the sim. If you joined before April 12, you'll lose the introductory pricing over the long term though.
According to Fizz, the line you want to transfer must be active with your old provider and must be done at the time of SIM activation.
Code_KRUEW was made best respondent
Nicholas answered
GOAT answered
Quang-Tri answered
Quang-Vinh answered
Code_KRUEW answered
Adam answered
Bill posted a new question
