A Plans info connection?
I was in Plattsburgh N.Y. and I didn't have any connection even in Canada beside the border no connection
Also
To call Ontario from Montreal it says it's a long distance calls
Why
  • GOAT
    GOAT Posts: 227 ✭✭
    Definitely contact Fizz support to have them look into this.
  • Georges S. #5813
    Georges S. #5813 Posts: 7 ✭✭
    Some problems happen cause of stabilization period.
  • Kenny L. #23
    Kenny L. #23 Posts: 794 ✭✭
    Make sure roaming on phone is on.
    Whizz Posts: 19,154 admin
    Hi Maze,
    To be able to use our services while you are in USA you will need to make sure that you have your Roaming data ON. After you check and set your APN settings properly, you need to manually connect to AT&T or T-Mobile for the best coverage in the country. Here you can find the steps to configure your APN: https://fizz.ca/en/faq/what-are-fizz-network-settings-apn .
    Have a good one!
    -Bogdan
  • Stéphane B. 10644
    Stéphane B. 10644 Posts: 786 ✭✭
    What more to add, it's so well documented by many members of the Community. Thanks.
