Intermittent issues for making or receiving calls and txt
Elyse B. #378
Posts: 19 ✭✭
in My Mobile
For the last 3 months I have been having issues intermittently making and receiving calls and txt. Nobody can reach me and neither can I. However my data works fine I am able to go to internet. Also intermittently my phone will say "roaming " or "not on the network ". I will probably need to change provider if these issues cannot be resolved. I have checked all settings and they are all correct as specified by Fizz. What should I do
11
There's not much to do.
That's the downside of being part of the stabilization period with a new provider.0 -
seems to be fixed now3
Others reported similar problem today. Those should be fixed now.
Here is the reply posted by Whizz Fizz Team:
"Hi Folks,
We had a small technical issue this morning, everything is back to normal! Thank you for your patience!"
@Maurizio, which phone are you using?
- Make sure you have latest OS updates on your phone.
- You can try reset it to factory settings.
1 -
HI Maurizio,
In order to be able to help you, please contact us via Facebook Messenger or Live Chat. On the following link you will find information regarding how you can do that: https://fizz.ca/en/contact-us .
Have a good one!
-Bogdan1
