What is the maximum timeframe length I can be in the United State with FIZZ? What happens if I exten
Nav
Nav Posts: 5 ✭✭
Iam planning on staying in the US more than 4 months, how much will it cost if I use FIZZ?
  • DinoS
    DinoS Posts: 626 ✭✭
    Use roaming for 3 months ad use travel add-on in 4th months.
    Whizz Posts: 18,801 admin
    Hello Nav,
    If you are planning to use your service outside our subscription area, you will be connected to Fizz through partner networks. If you chose to mainly use our partners network for more than 3 consecutive payment cycles your access to the network may be interrupted. Here you can find more info about this matter: https://fizz.ca/en/faq/partner-networks .
    Have a good one!
    -Bogdan
