Is it possible (and if so, how?) to access voicemail from my phone without entering a PIN?
Dominic R. #1352
Posts: 111 ✭✭
in My Mobile
It was possible when I was with Koodo; is there an option to activate for this?
61
I did not find the solution at the moment.5
It doesn't seem so any more.
However if you want to change your pin, just logon to your Fizz account.
Go to My Plan >> Manage Plan >> Advance Parameters >>
Click on PIN to access your voicemail and enter your new pin
5 -
Configure a speed dial with the voice mail phone number pause and your pin6
That’s a good question I have been wondering the same thing4
I configured a speed dial so everything is automated.3
It's impossible because (as I read somewhere in the forum), it seems that Fizz uses the services of Google Voice mailbox for his own voicemail. So to secure the system, it's necessary that each customer enter his own PIN number to access the system and the phone number as well if you try to enter the voicemail via another phone.4
