Hi! In order to lock my SIM in my cellphone, I need the 4 digits PIN that is provided by you. Since I only have 3 tries before my phone gets locked, I'd rather ask you for the...
Hi Jonathan
This is the procedure https://fizz.ca/en/faq/how-do-i-personalize-my-pin
How to personalize the PIN on most phones:
Go to the Settings menu → Choose...
Since there have been changes, here are the updated list of prices by component of mobile plans.
Please note: Existing customers are not affected until you change...
Winika To unblock your SIM card right away, log into your Fizz account to reveal your PUK code (My Plans > Manage > Unblock SIM card). Type the code that is revealed into your...
Hi everyone,
We’re so thrilled to see how much you appreciate the $35 referral bonus. Now, it’s time to streamline that excitement :)
No more referral code spamming. ...
if you used the PUK provided and does not work It seem like your phone is lock by another provider. Can you verify that?
Did you used the PUK from:
1- fizz account,
2 - In...
