Hi, I tranfered my number to Fizz a week ago. But the data is still not working. I checked the APN settings several times, tried to resend the notifications - there is always a message Error; I wrote to Fizz in Facebook - they told me exactly the same things. I don,t know what else to do? Should I cancel my contract? Is there somebody who can help me for real? Thanks
Your phone isn't compatible with Fizz for data : It's doesn't have band 4 which is required for LTE.
For an LTE-compatible phone configured with LTE network preferences:
Mobile data: Your device must have dual-frequency support for 1700/2100 MHz (also called AWS or band IV)
Unfortunately, Ulefone Gemini is not a supported device.
Are you sure the Ulefone Gemini is compatible with Fizz network? Because when I look at the phone's specs, it seems that this phone doesn't have the Band 4.
Hi, I don,t know if the phone has band4, but the others services are working. Do you think that it's possible that just the data doesn't work because of that? Thanks
If you have your answer, please select the best answer and close the discussion.
Fizzy was made best respondent
redhead answered
Fizzy answered
Galina answered
__________ answered
__________ answered
Galina posted a new question
