Subscription outside of Quebec or Ontario?
Brandon B. #5272
Posts: 1 ✭✭
in My Mobile
Is there anywhere I can check to see when I would be able to subscribe to Fizz in my area or just any plans they have to expand to the rest of Canada?
15
Yes you need to check here
https://fizz.ca/en/coverage13 -
You cannot subscribe outside of Quebec and the Ottawa area of Ontario.10
It's simple. You can't subscribe out of the coverage zone where Vidéotron have antennas. As simple as that. Check the subscription zone (in green) on the map to know if you can or can't subscribe to Fizz.8
Note: Vidéotron is the owner of Fizz. That's why I mentionned them.8
Fizz is only limited to Parts of Quebec and Onatrio6
Sadly, no it's not possible4
