reset my pin for voicemail
Juan V. #5267
Posts: 2 ✭✭
in My Mobile
Hi I don't have facebook and I don't have access to the chat bubble. I would like to reset my pin to access my voicemail. thank you.
8
Hello Juan,
If you want a new voicemail PIN code, you can change it by going to "My plans"/"Manage plan"/"Advanced parameters"/"PIN to access your voicemail" . On the following you can find all the info: https://fizz.ca/en/faq/how-do-i-set-up-my-voice-mail .
Have a good one.
-Bogdan3
