Why does my cellular data not work?
Adam B. #5155
Adam B. #5155 Posts: 2 ✭✭
My cellular data doesn't work even though I can make calls and send SMS. I'm on the latest version of IOS by the way so I can't update my software. Also, it tells me to activate my plan in my profile even though I already did. I followd the steps for the APN but still nothing. My carrier is Fizz 36.0
    Fizzy Posts: 10,815 ✭✭
    You can try this. It worked for me.
    You need to manually edit both APN. For both APN, change "APN protocol" and "APN roaming protocol" to "IPv4/IPv6" instead of "IPv4".
