Why can i not adjust my plan?
Alex M. #2475
Alex M. #2475 Posts: 122 ✭✭
Trying to adjust my plan and a red warning pops up saying billing cycle is invalid. My plan does not end for 15 days so what is the issue?
  • Chris P. #37
    Chris P. #37 Posts: 141 ✭✭
    Yes, you should try to contact Fizz either on the help page or by using facebook messenger. I've also seen this issue with my account too, but I probably wouldnt recommend changing your plan if you had the introductory prices cause if you do, you will lose all of the discounts.
