Unanswered question
If i add a bonus and then change my plan, will that bonus remain and refresh every month or will be deleted?
Since bonus are tied to your account, they should stay even if you change your plan. Unless it's a data bonus and your new plan doesn't have some.
I have a data bonus and dont have data plan! You can have a data bonus with any plan.
@VincentMG you mean a perk? A data bonus that once used is over or an upgrade that's applied every month?
Please be more specific. When you say bonus, do you mean perk or rewards upgrade?
Bonjour, Hi
Data bonus = Upgrade. My bad!
Yes upgrades will remain even if you change your plan.
UPGRADES remain valid for 24 months from date of APPLY, not date of RECEIPT.
Bonuses are tied to your profile, not your plan, so as long as you remain a customer with Fizz, you retain the bonus for the timeline of it.
