Unanswered question
Hi Fizz, when you will hire an employee to start working out bilateral roaming agreements with other MNOs? Talking about voice here and not sms/data which are easier to setup through hubs.. https://www.gsma.com/publicpolicy/wp-content/uploads/2012...
Hello Michel,
The voice service for roaming will be available by the end of the year. Here you have all the information about the roaming options: https://fizz.ca/en/faq/im-travelling-outside-my-coverage-... .
-Bogdan
I think you should ask the FIzz costumer support. They may be the best to answer your question.
An alternative: if you have an esim enabled device, check out Airalo. You can get 1GB of data valid for 7 days for 3$.
redhead answered
Ohthatvank answered
Whizz answered
Michel posted a new question
