Is it possible to select 100 minutes?
Rohan R.
Posts: 18 ✭✭
The slider is 0 or unlimted.
8
No, as you said, it's all or nothing.7
If you do not want unlimited talk, you can rather buy talk add-ons every month.
Go to your account and check out the packages available to you.4 -
On April 12, the add on available for voice calls are:
- $10.00 for 300 min. of calls
or
- $3.00 for 60 min. of calls7 -
1. Basically, select 0 minute for the plan.
2. Confirm the plan.
3. Then go to your Plans in your Account and add Add-Ons to your current plan.
l
There are only two available add-ons for your specific need at this moment:
- 3$ - 60 mins of call
- 10$ - 300 mins of call
So for you, the best would be to add 60 minutes twice.1 -
I believe that you got your answer, can you please, close the post?5
