Or do i have to by any extra adds on in order for me to use the data in the US (I already bought data usage in cad)
Absolutely!
You can use that plan anywhere in Canada & the USA.
Calls, texts and data will work in Canada and in the USA.
Yes you can use it. You can call canada from NY
Yes, if you buy a "Canada+USA" plan, you can call / text Canadian or US numbers from Canada or the US and you can use your data from Canada or from the US.
This answer is undergoing moderation. It will have to be approved by the administrators before it is made public
R1ck_D
Yes, like stated in previous post , but no more than 3 (consecutive ?) month.
Have a safe trip.
You're work load not big enough as I can see.
Just to make sure that you have set the correct APN settings:
https://fizz.ca/en/faq/im-travelling-outside-my-coverage-...
Good luck!
Yes, but for no more than 3 consecutive months in a year.
