Hi Guys,
I am interested in Fizz mostly for the travel addons, they are extremely great!
I would like to have a Fizz SIM for travel only, and I was thinking of having:
It would be 10 a month for no service just to keep the SIM active.
Will I be able to add a Data Add on for Mexico for instance?
Or do I need some data, like 1gb in the plan, so the travel addons work?
I know the easy fix would be to just port my number to Fizz, but I currently pay 3 dollars a month in Public Mobile (thanks to referrals) and it would be a waste to let that go.
Thank you,
JL.
The Quebec-only plan with no services, just the network fees, is actually $8+tax if you subscribe by the end of April. After April, it will be $10+tax.
There is no problem with your idea, Jairo. Some people use the plan with no services and pay as you go.
Note also that travel add-ons are good for the current billing cycle and the next. Depending on how often you travel to Mexico, if you have leftover money in your travel add-ons you might still use it on your next trip there or pass the sim card to someone.
I do not see any problem, since an addons will add a service that you do not have.
The add-ons do not have a launch price, therefore, you do not really need to keep active the SIM.
I believe that you can unsubscribe https://community.fizz.ca/questions/1939891-minimum-plan-travel-addons-work
Check #5
After you close your plan you can give your SIM card to a friend. They can use it to activate their own Fizz plan (with their own settings, etc.). This will save them from having to buy their own SIM card.
The activation code for your SIM card is entered by default in the reactivation process for your Fizz plan. With this number, your SIM card can be associated with any Fizz plan.
Hi Irene,
Thank you for your answer.
Could you please paste the link again? The link you pasted is the link to this thread.
Thank you,
Jairo.
Add on work for the Minimum plan for Travel addons, my friend use his card at China now. Fizz card data can check gmail, Facebook with out VPN.
I confirmed with Support, that the Quebec Plan for $8 bucks with no calls, no text, no data, WILL work as a travel SIM with Travel Add-ons only.
Kovid was made best respondent
Jairo Leon answered
Wayne answered
Kovid answered
ZGuo answered
Jairo Leon answered
Jairo Leon answered
irene answered
Jairo Leon posted a new question
