Account says Canada-wide plan, but cannot make calls to Ontario numbers?!?!
Lucas Barbeau
Posts: 2 ✭✭
in My Mobile
I made the adjustment to my plan of Canada wide calling after being unable to make calls to Ottawa/Ontario numbers. This has been added to my new billing cycle which started the 19th of this month. I am STILL unable to make calls to 613/343/ Ontario numbers! Getting real sick of having problems, as this is far from the first problem I’ve encountered with this company.
Any help would be appreciated.
If you go in your Plan -> Manage Plan do you see the new coverage?
Did you try add +1 or remove it?5 -
Munch plan states that I have Canada wide coverage. I’ve tried the numbers with and without +1.2
Is working with 1613 or +1613 I called Carleton University from mtl
Then if you have the plan and it does not work contact the support
Go on this page https://fizz.ca/en/faq/resolving-issues, if you are not connect login
Wait 15 seconds for the bubble icon to appear at the bottom right of the browser and click on the icon
Your can also send a message by facebook
https://facebook.com/fizzca and click send a message (this is a bit slower)2 -
Hello Lucas Barbeau,
In order to be able to help you, please contact us via Facebook Messenger or Live Chat. On the following link you will find information regarding how you can do that: https://fizz.ca/en/contact-us .
Have a wonderful day!
-Bogdan1
