Unanswered question
I tried many things Resending the network parameters (error message), manually added, still i can not send MMS... and yes I have 13 GB data....
What phone are you using?
I can't see enough of your APN settings to see if you are missing anything. Have you tried turning off wifi when you try to send a message (because the mobile state indicates "disconnected" in the screenshot, and you need mobile data to send mms)?
There are other settings to set for the APN that aren't shown in your screenshot. The required settings are listed here: https://fizz.ca/en/faq/what-are-fizz-network-settings-apn
According to their Launch FAQ:
Fizz is currently working to resolve the following issues within the very near future:
You look like you are connected to WiFi at the moment, have you tried disabling WiFi and sending while connected to the mobile network?
Pay particular attention to the Proxy MMS and APN type setting as you didn't include those parameters in your screen shot.
Ok yes I disconnect WIFI and try again to send MMS. Still no working. My phone is LG G6.
@christian seulement pour être certain, si tu as plusieurs APN tu dois l'activer
@Mike oui, je crois comme ceci....
Please confirm whether you are connected to the Internet.
I have encountered this problem as well.
If data is turned on and you are not connected, you may need to manually select one of the FIZZ EXT networks.
@Fizzy... Which one and how to connect to them ? FIZZ EXT networks.
Make sure roaming is enabled.
Go to settings.
> Mobile data
> Mobile networks
> Network operators
> Search networks
> Pick any one of the 'FIZZ EXT'
If problems, you can try online search
"how to change mobile network on lg g6"
Hope this helps
