Hi, just activated my SIM yesterday. Call and text seems to be working. But there's no data. Phone is updated to the newest iOS 12.2, no carrier update popup when in the settings->general->about. Carrier says Fizz 36.0. Tried everything, still no data. Anyone can help?? Thanks.
Hi Wangyi,
If you're still experiencing this issue, I'm kindly asking you to contact us in private by chat or Facebook messenger. You can find the info for reaching us on the following link: https://fizz.ca/en/contact-us.
Have a great day!
Radu
You need to verify the APN
You need to configure the APN in order to be able to use the network
Here how to do
If activated just yesterday, may take some time
May try to reset network settings in your iPhone settings as well.
If your plan as data you should be able to use it. Try to restart your phone. Your APN seems fine I got the same thing.
if your plan doesn't have data on it you will have to add some money in your wallet.
try fixing your apn
Guys stop saying APN APN APN
IPHONE DOES NOT HAVE APN
I would just contact fizz if i were you
