The data stopped working on my phone today. I can make a phone call but it will not let me use data.
i have the APN setup how it should be and ALWAYS has been for years...
Hi MB
Check if you still have data from your account
Also check if you do not have any data limit usage on your phone
Settings → Connections → Mobile data usage
If...
Hello! I’m new to fizz and i want to know to upsides and downsides to fizz. I keep hearing that one of the best perks is that you get to save the data you didn’t use the...
Hi Ibrahima
Fizz mobile service is prepaid, so there are never any surprise bills.
Fizz is unique and 100% online. Check here to see some of the benefits: https://fizz...
Ok, I did all you asked and even more since Friday. I tried band steering mode, without steering, only 2.4 g, only 5g, both 2.4 and 5. I tried auto channels. I did factory...
Hi Sergey
Yes the firmware has some bugs.
After performing a factory reset, please redo the customization changes.
Manually select the WiFi channels you want to use...
So I’ve had issues with Fizz for over a week with Fizz canceling my plan not once but twice (and me being unable to work since we can’t go to the office). I finally received the...
I know I tried to have the bubble chat this morning...after 30 minutes it appeared. Be patient...that’s all I can say ...sorry for you. It looks like we need to learn patience...
Hello Stephane,
Sorry about this, this here a forum with customers like you. Her is the way to contact Fizz, all is online, you cannot contact them by phone.
Log into your...
