I don't have network since 9 am. Can you solve the problem ?
shariful hussain
Posts: 1 ✭✭
in My Mobile
3
Has been down all morning https://fizz.ca/en/faq/status-services3
For me, mobile service is completely down. Some areas like Ottawa still working.
Fizz must be doing a reset. Roaming doesn't work either now.
At least Fizz is posting updates to keep us informed every hour.
Check here for status updates: https://fizz.ca/en/faq/status-services
I keep a 2nd mobile line as backup with another provider. It's been pretty reliable also prepaid, similar to Fizz. I hope Fizz improves soon.
6 -
Service is dead for now https://fizz.ca/en/faq/status-services3
they are back1
Can you close the post choosing the best answer by clicking on the button. Thanks
1
