Out of plan data charge
ZGuo
ZGuo Posts: 23 ✭✭
What happens if my data usage pass my plan allowed amount, how much I will be charged or simply I can not use data?
  • gremiobr
    gremiobr Posts: 237 ✭✭
    If you don’t have money in the wallet, the data won’t work.
  • DavidP
    DavidP Posts: 301 ✭✭
    You won’t be able to use your data. If you want you need an add-on.
  • Serge O. #3665
    Serge O. #3665 Posts: 535 ✭✭
    Data won t work. It is prepaid so it Will stop To work but you will be able To send mms
  • Spiltz
    Spiltz Posts: 1 ✭✭
    Fizz is a pre-paid service. So no extra fees on your bill unless you.. pay them in advance. :)
