Unanswered question
I attached my 3TB USB hard drive to my Fizz router but I'm getting very slow transfer speeds of only 1MBps. I tried accessing the drive from both a Win 7 and a Win 10 PC but I'm getting the same slow speed. I figured it should be able to transfer at least 10MBps considering the specs of the Fizz router. Anyone have experience getting faster speed out of this router ?
The USB 3 is 640MBps the USB2 is 60Mbps therefore you are too slow.
Are you connected in WiFi or ethernet?
Yes it's very slow. Same for Rogers modem
What type of USB hard drive do you have attached ? You need to find out what's causing the bottleneck and in your case, I believe it's your hard drive.
Do you have a USB 3 usb stick ? Or a different USB 2.0 usb stick ? You can try plugging in another drive to single out the problem.
Good luck :)
I stumbled here looking for an answer to that same issue. I have a 3TB USB3 external harddrive hooked up to the modem and I can only get a speed of 930KB/s when transfering a 1GB file to it.
I used to have a DLINK DIR-865 router with a similar USB3 plug for an external hard drive and I was getting a transfer speed of 11MB/s with the same 3TB hard drive.
I mean that plug on the back of the modem really is USB3, right? It does say so on the Hitron CODA-4680 web page.
I guess I should upload the hard drive content to cloud storage then? The upload speed it faster than 930KB/s
Yes it's very slow. Sorry but is the modem... not your DD
