Does not work for me sms
Hello Yakoov ,
I can see in my tools that your services are fully functionally.If you have any inconvenience please contact us via chat or Facebook Messenger : https://fizz.ca/en/contact-us .
Marius Daniel
To received them or to send. If it is for receiving, from which provider
Did you just activate recently ? If so it may take up to 2 hours in order for you to be able to use all features in your plan
It may takes up to 2 hours before the transfer is fully completed.
Please contact Fizz and make your problem clearly described. My Profile --> contact us
Do you have reception ? Are you using MMS ? Did you try texting with our without wifi ? If you are using MMS, you should activate your 250mb of free data and see if that helps.
Cheers.
