I have the unlimited messages, unlimited minutes, and 2Gb data, on Canada and USA plan.
It seems to me that MMS messages are using data from my data allotment. Is this normal? Most providers don't count MMS messages as data. Fizz does say Unlimited Text messages, so maybe they mean on SMS and not MMS. I guess I took it for granted that MMS was included in the Unlimited Text messages. Anybody else notice this?
MMS uses a tiny little bit of data. But it does. This is why everyone starts off with 250mb of free data, and eventually gets another gift of 500mb. I think Fizz doesn't really say it, but this is to cover for the data that one might be using while MMS'ing. That amount of data will cover you for years to come in terms of MMS messages.
With Fizz you need data to use MMS and yes MMS does use your data.
Sending mms uses data.
Unfortunately yes u need data
Yes, you need data and MMS doesn't work with wifi
Yes it's use data
yes it uses data but not a lot
