I installed the 2 configuration files for fizz networking setup, tried manual settings , it shows 3G connection, data on, I receive text msg, can make calls but cannot browse the internet:
Here are my phone compatibilities (android 5.1)
BANDS OF HOMTOM HT7
HomTom HT7
View datasheet
Tecnology Version Bands
5G
4G LTE
3G
B1 (2100), B2 (1900), B5 (850)
2G
B2 (1900), B3 (1800), B5 (850), B8 (900)
I went on a site(https://www.kimovil.com/en/frequency-checker/CA/doogee-ho...) and it says is not compatible with videotron mobile data network, will it work on fizz?
B4 1700/2100 aws-a-f is crossed out
Cosmin:
You need to reach out to Fizz by Chat to address the issue. I also had network configuration issue as well but Fizz was able to help.
Your phone is only compatible with Fizz for Voice.
But it isn't compatible with Fizz for data : It's doesn't have band 4 which is required for LTE.
For an LTE-compatible phone configured with LTE network preferences:
Calls: Your device must support HSPA 850 MHz or 1900 MHz frequencies
Mobile data: Your device must have dual-frequency support for 1700/2100 MHz (also called AWS or band IV)
Hello, Cosmin!
Unfortunately, HomTom HT7 is not a supported device.
Respectfully,
Jiri
