If you google "voicemail security vulnerability length" you will discover that 4-digit voicemail PINs are highly vulnerable and because many services (including banks) use SMS...
Hello Gili,
I appreciate your concern about your privacy and for this suggestion.
I will send it to the respective team that handles our suggestions and the privacy to have...
I'm trying to activate my voicemail, but I forgot my PIN. I tried to change my PIN in the Advanced Parameters --> PIN to Access my Voicemail, but when I enter 4 digits (that...
After my first set up of the PIN code i could not access my voicemail, the PIN that i entered is not working even though i am certain that i'm inserting the correct PIN. So i...
Hi Andrew
Modifiy your access code (PIN) to access your voicemail online, directly from your Fizz account.
(Under: My plans > Manage my plan > Advanced parameters > PIN...
Hello ! It seems like my voicemail access is blocked because of wrong Pins. I have a message on there that I absolutely need to listen to. How long until the voicemail is...
Hi Manon,
Update the PIN to access your voicemail whenever you want.
Log on your account My plans >> Manage plan >> Advanced parameters >> PIN to access your voicemail...
I was way to quick to set up my voicemail and didn’t use the correct password provided in the text they send once you activate phone. The icon says I have 3 voicemails, but when...
Hi Julia
You can modify the pin
Modify your access code (PIN) directly via your voicemail, or online from your Fizz account
(Under: My Plans → Manage My Plan →...
