Data not working for three days, solution in sight?
You can not rely on the status page.
Have you tried to disable mobile service and enable mobile service to see if help6 -
Gosh... Yup that worked. Very strange. I deleted APN and entered it again and reset the phone even. Somehow the thing that worked was what you suggested.3
Are my APN settings fine and at the optimal?3
