My message Mms does'nt work?
Do you have data on your plan? MMS requires data to be able to download those images or video. Your APN settings are also important so make sure the MMS section is correct.8
Try to double check your settings
Also do you have DATA plan ?6 -
So we should absolutly use our mobile data?
We can not use the home wifi?3
