when checking the travel options online i only see the options for data and text, for minutes there is n/a. does that mean that i wont be able to call out while overseas?
Hi Abraham,
You will not be able to make calls while roaming outside Canada and the US. Roaming calls will be available soon.
In the meantime, you will be able to use data, and send/receive texts when you travel outside Canada and the US. To make and receive calls, you can use messaging apps such as WhatsApp or Messenger. Thank you for your kind understanding.
Have a great day!
Radu
Fizz does not offer roaming calls in Europe. You should buy local sim instead.
Unfortunately yes, as Fizz is still growing up...
You should use local sim instead.
As suggested by Lei, I would also recommend that you buy a sim card during your travel. This is the advantage of having an unlocked phone.
Bingo you'll have to use an europe Sim with an europe number
