I chose the 60mbs option and was wondering if I could switch to the 30mbs later on if I found that I wouldn't need it later on.
@Micah: I'm pretty sure this issue was resolved. Last post was 6 months ago :-))
Yes but oyu have to do it before beta ends
Or else you will have to pay the 'normal' price
Yes, but the change won't be in effect until the next billing cycle.
Jia,
@Gyslain and @Dominic are both correct!
Jay
Anyone knows if the change in speed is transparent without any modem change or a visit from the Technician?
Speed change can be done from the website without technician intervention and nor modem change
@M - Spot on :)
Jay
Ayy Alright thanks guys <3
of course you can switch
Yes you will be able to change you internet speed at any time :) It will become effective during your next billing period. In theory you can edit your speed every month
@Yelena: you are absolutely right :S haha my bad
