Unanswered question
Kudo (heart ) only give one point but when i haved clic on it a pop up say 50 points,
THanks
Kudos are worth 1 point when you give and 5 when you receive
If I remember correctly
Gyslain you're right 1point when we give and 5 points when we receive
Point for point I give everybody points in the community :D nice to give back and also receive
For the first time, I have got more than 1 (I don't remember how much it was), afterwards it is 1.
50 points is for the best answer to a question, as chosen by the author or by a Fizz moderator.
The 50 points you earn were more likely because of your first interaction on the forum, as Apprentice 1/5.
Chizz :))
Now I cannot give kudos to anyone. There is some issue I think. I can login to community hub, I can reply, ask question, but I cannot see my points and give kudos...
I'm having the same problem with not being able to give kudos today. I can log in and reply to comments, but clicking on the hearts does nothing. Discovering different new bugs is just part of the fun at Fizz!
Best worth 50 points.
That must be a mistake, I wish it gave 50 points.
