Unanswered question
Dear Fizz community
Would like to know more about Fizz’s provide Modem coda 4680
1/Does it has limited of many devices users ?
2/Does it need to disable Residential Gateway function, when you turn off wifi of coda 4680 modem?
3/ what is the advantage to use my own more power wireless router ( like Asus ac5300)
Thanks
Also interested in this question
Here are the answers
1) In theory, you can use 253 users (192.168.0.2 to 192.168.0.254) , but your modem will be dead if you have more than 50 or less users running in same time;
2) If you want put it in bridge modem (disable router), that's the option you need disable. To disable wifi, just disable wireless;
3) You have better signal and more control on your wireless network if you use ASUS AC5300.
On paper Asus ac5300 seems to be better ( 3 bands : 2 x 5G and 1 x 2.4G).
The only way to know is benchmark
login to web and turn off wifi.
