Dear I want to know does Fizz mobile support esim or will support near future? I want to have a back up second phone number for some reason.
iPhone XS , XS Max or XR?
Thanks
Fizz does not support esim at the moment.
Not for Fizz, nor Videotron. They may in future but it will be Fizz's last item in to-do list.
I doubt fizz will support it until at least Videotron supports it
And Vidéotron has no plans for that
No you can't get a plan on your esim for your iPhone or Apple Watch but you can get one via the standard sim.
I’m looking at dual physical sim iPhone China version spec now. 2nd sim only supports 2g. So android is better option for dual sim users.
