US 60 Minutes add on does it expire?
All add-ons expire on the following billing cycle or if you use it all. If you buy it on the first day of your cycle, you have 2 months. If you buy it on the last day, you have about 1 month before the add-on expires. Of course, if you use up your minutes, you'll have to buy another one :-)3
Add on expires after the end of the following bill cycle even you have not use it at all.3
Yes it will expired in your next billing cycle. In theory, it last max 60 days if you active it in first day of your current billing cycle.1
Adds-ons always expire after your next payment cycle. They are only available for the current cycle.1
