Do you need to put your sim card inside your cellphone to activate the sim card?
madeleine B. 7285
Posts: 2 ✭✭
in My Mobile
Do you need to put your sim card inside the phone to activate your sim card?
7
The activation is done thru web site.
It would be better to have sim card in the phone so you can receive an notification and test it.6 -
No there are instructions on the packaging around the SIM card that tells you when to put it in.6
NO need, just use web is ok5
