Are there any charges for calling 1800 phone numbers?
  • Francis V. #452
    Francis V. #452 Posts: 72 ✭✭
    No but you would still need minutes to make the call. Emergency services will always work though.
  • DinoS
    DinoS Posts: 626 ✭✭
    It's free if your plan has call minutes. It will cost your minutes if you're on pay as you go (use addon or use wallet).
  • M T. #338
    M T. #338 Posts: 2,934 ✭✭
    Air time is always charged even for your voice mail .
  • Leifuer
    Leifuer Posts: 494 ✭✭
    No if you have minutes in your plan.
    Yes if you buy the adds-on and put money in your Wallet.
    Whizz Posts: 18,785 admin
    Hi Jasmine,
    If the number that starts with 1 800 is a free number the call will be possible only if your plan includes minutes or and add-on for minutes. If the number has fees you will be charged from the wallet but if the wallet has no founds the call will not be possible.
    Have a great day!
    Georgiana
