My Fido account has two phone lines. I worry that I'll might have issues transferring both lines, since I'll be using one account number.
Did anyone have similar experience to share?
You should be able to do this without any problem because you are giving the account number and the phone number that you are porting over. There will be no mix up because of the phone number.
One thing that you should keep in mind is that you want to port the second number first, not the primary number. If you port the primary number first, your account will be closed and the second line will be cancelled.
My suggestion is that you port the second number, wait until it is completely working, and you get the confirmation e-mail that the port was successful before porting the primary number on the account. Good luck
You'll need 2 sims cards. You probably gonna be able to use the same accont if you want
Maybe you can use also the IMEI in this case.
Yes you can and here is how to transfer to Fizz information https://fizz.ca/en/faq/activation-how-do-i-transfer-my-cu...
Code_KRUEW was made best respondent
Code_KRUEW answered
MT answered
DavidP answered
Johanne answered
Yuri posted a new question
