Hey Guys
Hope you're doing well , question plz , sometimes i have a cut on my wifi when im round 10 to 15m from my router, is there anyone who's experiencing same problem ??
thanks for your replay :)
Hi Hichem,
This is a known issue with some customers - This should be fixed by tomorrow morning :)
Jay
Apparently, modem's WiFi is not very efficient. Some users gave up and installed third party WiFi router.
Check if there is a firmware update available for the modem or a setting to increase signal strength.
Chizz :))
Turn off ATF would help improving wifi experience.
Use 5g only may help
Thanks for your replies , so i'm not the only one ,
@Tom I did use only the 5g it didn't help ,
@MT How can i turn off ATF on fizz router , if you could just make a resume plz
It should be in wireless settings .
I have the same problem.
You found a solution?
@Francois , no i didn't most of time it is good , till now
My WIFI is also acting wonky, I set a specific WIFI channel known to have less interference on the 2.4Ghz and it would change channel on its own, I was using those channels just fine with my Bell Hub 2000 before.
Same for 5Ghz, you can set a channel and bandwidth but the modem will change on its own!!
Tried 20Mhz on ISM channel 165...next day it's back to 36... ISM and UNI-3 shouldn't be even be a DFS channels so I'm not sure what is going on.
When I enabled DFS, I expect to be able to use UNI-2 channels but no, only UNI-1 36-48 (which have lower max output signal than channel 149+) and UNI-3 and ISM.
Tried 149 at 80Mhz...sometimes jump to 161 and/or set itself to 40Mhz.
Currently on 40Mhz ch 161, lots of Bell Fibe modem/receivers hogging ch 149...so i'm trying to avoid interferences
