It doesn't recognize my address when I trying to order a Sim card?
Jerry S.
Posts: 1 ✭✭
How do I order if it not taking my address?
2
It's happened to a lot of persons. Someone whould be able to help you but you can also make a surch on the forum.2
Are you within the subscription zone? https://fizz.ca/en/coverage
If you are not in the subscription zone, you can not order a SIM card. If you are, I would suggest getting in contact with support.
1
