Do we need to have a data plan in order to receive data gifts when you go up in a level ??
Shilgi
Shilgi Posts: 191 ✭✭
Can I Use my data gift ???
  • Shilgi
    So why doesn it work for me ??
  • Mathieu C. 6085
    Mathieu C. 6085 Posts: 4 ✭✭
    I had the same issue as you! Just wait until your next billing cycle and you should be able to use your data gift.
  • DinoS
    DinoS Posts: 626 ✭✭
    It doesn't matter which level, You do need a data plan to receive data gift. For data perks, you can receive it without data plan. Data perks is one time and everybody only has one.
