If only 15 to 60mbps options are showing, will I have access to 120mbps someday ?
I know that as for now, some plans are not available in some areas. But I'm in Montreal near downtown so I guess 120mbps will be available sooner or later for my area. My question is, when that happens, will I have the 40$ price and could just upgrade my 35$ plan to that one ?
I asked support that question the other day, and they pretty much said that IF it comes back during the Beta period at the discounted price, then yes will be able to upgrade to it no problem.
Did you find this useful ?
No (0)
Yes (0)
MT
MT
MT
Level
5000 / 5000
Someone in forum has a 120Mbs internet speed so very likely you'll get it eventually.
However if you'll change your plan eventually you'll loose your beta price.
Anne
Anne
Anne
Level
5000 / 5000
Max 60m now as I heard.
Marc
Marc
Marc
Level
2
1085 / 2000
I think they will provide 120mbps in the near future, considering lots of demand.
Matthew
Matthew
Matthew
Level
2
949 / 2000
If you are downtown, it's surprising the speed isn't available to you unless they are specifically only offering certain packages.
If you look on videotron, what speeds are available to you?
