Roaming text and data
I understand the concept of roaming when making phone calls outside of the selected coverage area
Does the same limitations apply to texting or using data while in another province with coverage only in “quebec”? Or is it strictly calling?
  • Kenny L. #23
    Kenny L. #23 Posts: 794 ✭✭
    Yes, it applies to the entire plan.
