I have 2GB data plan now and I dont use all my data every month and so have more unused data in my account. now If i downgrade my plan to 1 GB will i still getting my unused data?
Your existing data should rollover however you're only able to keep that data for 2 months. Since you can only rollover data for up to 2 months, you'd lose that extra chunk of data from the 2GB plan after two months.
I'm not sure but I think yes until you have a plan with date.
Should be fine as long as you have an active data plan.
Yes you'll get the unused data rolled over to the next month as long as you have data in your plan.
