my lte doesn't want to work
I don't understand why my data doesn't want to work. I have chosen the 6gb program. My iPhone is compatible ( it is the 6s) and I can text and call but I cannot use the data. I don't understand... I restarted my phone also. When I go on google for example it says " could not activate cellular data network" turn on cellar even though it is activated and on the top its written " fizz lte" I dont understand....
Kheira Djatou
Kheira Djatou
Kheira Djatou
Level
point
You're using iphone,you just need go to General ---> Upgrade firmware to 12.1 or above. Reboot phone, and you'll get data running after.
iPhone is known not working with Fizz for lower firmware version.
Did you find this useful ?
No (0)
Yes (0)
Alexandre
Alexandre
Alexandre
Level
Yeah service is down... again
Service is ok for me, I don't think it's down.
Check here to update your APN stetting. https://fizz.ca/en/faq/what-are-fizz-network-settings-apn
Also, if you just activated your SIM card it might take a while before it's fully operational.
Chizz :))
Alexandre
Alexandre
Alexandre
Level
LTE and 3G were definitely not accessible for me for the past hour or so, I've been stuck on the H+ since then.
I just was able to finally connect to LTE network as of a few moments ago.
Alexandre
Alexandre
Alexandre
Level
lol, most of the time they don't even log the issues they have, by experience for the past few months
Marc
Marc
Marc
Level
2
1085 / 2000
Try to reset your iphone's network settings.
