Hi, ive activated my sim card yesterday and everything work exept my data. I have rebooted my Samsung S7 severals time but even that wont make my data LTE to work. Do you have any way to fix that problem?
Manually input your APN settings. Make sure you have roaming enabled if you're out of the subscription area. Some people have had problems with the S7 and Fizz data though, even though it should work.
Check and double check your APN settings, especially for typos. Take a look here: https://fizz.ca/en/faq/what-are-fizz-network-settings-apn
Are your settings right? Prefered Network 4G? Do you get 4G or you are in 3G? Is cellular data On? Turn off Wi-Fi to see the little LTE icon. Do you get SMS?
ALLISON was made best respondent
Code_KRUEW was made best respondent
Mario_D was made best respondent
Mario_D answered
ALLISON answered
Code_KRUEW answered
Kevin posted a new question
