Because the phone I currently use is older, a Samsung Galaxy S6 that has seen better days, I'm looking for something else and I found one that I would like but it has this written on the listing:
"These phones are Sprint unlocked and will work with any GSM provider: Rogers, Fido, Bell, Virgin, Telus, Koodo, AT&T, etc. This phone will NOT work on Wind Mobile/ Freedom, Chatr."
Is Fizz considered a GSM provider? If yes, I shouldn't have any issue using this phone with Fizz, correct?
Galaxy S6 should work perfectly on Fizz
Chizz :))
Galaxy S6 Specs:
Network Technology
GSM / HSPA / LTE
2G bands GSM 850 / 900 / 1800 / 1900
3G bands HSDPA 850 / 900 / 1900 / 2100
4G bands LTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 8(900), 12(700), 17(700), 18(800), 19(800), 20(800), 26(850)
Speed HSPA 42.2/5.76 Mbps, LTE-A Cat6 300/50 Mbps
GPRS Yes
EDGE Yes
fizz is not a gsm provider, that means 2G. Fizz is 3g and 4g only.
If it's working on vidéodron, il will work on Fizz. The phone need band 4 and will work better with also the band 7.
the Samsung S6 should be compatible with Fizz on 3G & 4G network. It's compatible to use on the Videotron Network.
For all old phones, you can verify if the phone is compatible or not with a specific carrier from this useful site: https://willmyphonework.net
