Unanswered question
When on cellular data, I only get 3G. Also, the option for LTE is enabled on my iPhone and my plan was activated as well. Does anyone know why?
Thanks
•---------• Version en Français •---------•
Sur les données cellulaires, je ne reçois que la 3G. En outre, l'option pour LTE est activée sur mon iPhone et mon forfait a également été activé. Quelqu'un sait-il pourquoi?
Merci
Are you indoors or outdoors when you're stuck on 3G? I get lte outdoors, but 3G in my basement. Main floor varies between the two.
I've resolved the issue by restarting. Thanks for your help anyways.
