Unanswered question
When I go to the SIM status section of my phone, it says my phone number is "unknown". Is that also the case for other users?
It's supposed to display your phone number
I have same problem. It doesn't recognize my Fizz number. My phone can show Rogers, Videotron, and Freedom sim card number just fine. Confirmed it's the phone problem. (using Android 7.1). Data/sms/call all works, so I don't care this minor bug.
Mine is even weirder : it shows a random number . Maybe it's because I ported.
Mine shows unknown as well...
