Just click to apply the upgrade first then click on the current one and choose swap!
The answer’s here for those concerned about loosing the upgrade if they remove it : https://community.fizz.ca/questions/1845941-anyone-able-switch-upgrades-yet#answer_4219466
What happens to the upgrade that you remove though? Is it lost or does it return to your upgrade list? That's my concern with trying to swap out upgrades.
I spammed the swap button and nothing seemed to happen. So I removed the upgrade instead. Now got to wait two next billing cycle for my new upgrade to take effect! #sadpotato
Nice! Hopefully you don't lose the upgrade you swapped out.
